Problem with power to main relay
1995 civic cx. Problem is that the main relay does not get power from the ignition. So i was wondering if the key ignition has anything to do with it?
Other then that if i supply a 12v source to the relay i can start my car up. Any input is appreciated.
Re: Problem with power to main relay (kac3r)
did you fix this yet? i'm having the same problem and it's really inconvenient carpooling. My car ran fine, parked it and now it wont start. I've checked all the fuses and grounds. I also used a multimeter and found that no power is getting to the main relay. it is not clicking when i turn it to on. There is definitely no power going into the main relay when key is turn to on. Do you have any ideas? thanks
ham
10-28-2004 03:40 PM
