Wheel Hub & Bearing
Wheel Hub & Bearing
Hi,
It seems like my rear wheel bearings are going out(they howl). Should I replace the wheel hub as well while im at it? If so is there an aftermarket brand that you guys like? What are the benefits?Throw me a site if possible
Vehicle is a 94 Del Sol Vtec (Yes with Discs on the back)
Re: Wheel Hub & Bearing (instructor74)
oh no ****
i thought that you could just get the bearings pressed in.
Is there a better after market one I should look at? If so link me if not where do you suggest I buy them from.
Re: Wheel Hub & Bearing (shadhman)
http://www.hondaautomotivepart...EC%29
Here's where to find out how, delsol's may be in the civic manual, I just checked mine, no. But the rear bearings must be the same as a Si
http://hondatech.info/downloads/Auto/Manuals/
http://www.partsamerica.com/Pr...Set=A
Modified by 1992Si at 7:46 PM 7/22/2008
They recommend you replace the axle nut as well.
If you've never broken torque on an axle nut, you want to break torque with the car on the ground, it's 134ftlbs. If it's like the front nut it takes a 32mm socket, get a 1/2" breaker bar and a 3 ft pipe or a 3/4" impact gun with at least 150psi of air.
PaChiLa Leader
02-18-2009 05:21 PM
redman223
04-30-2007 02:36 PM
