Hard wiring reverse lights in EG.
Old 07-22-2008, 05:32 PM
Hookeduphatch's Avatar
Default Hard wiring reverse lights in EG.
My reverse lights do not come on when in reverse. I am going to hard wire the reverse lights. I want to make sure i am doing it right. There should be a plug on top of the tranny... one wire? connect that wire to a positive on the reverse bulbs. I only need to connect to one of the two sockets and they both should work? Does this sound correct?
Old 07-22-2008, 07:02 PM
Default Re: Hard wiring reverse lights in EG. (Hookeduphatch)
people are reading but i am not getting any conformations. Am I wrong or people dont know?
Old 07-23-2008, 06:28 AM
bump****
Old 07-23-2008, 06:40 AM
Mr. Badwrench
boostedcivicsir's Avatar
at the bottom of the trans, there is a 2 pin switch. key on one is hot, the other goes to the reverse light circuit.
with that said, key on, jumping that connector (as long as the switch is the problem) will light the reverse lights.
Old 07-23-2008, 01:16 PM
blk92_d16's Avatar
Remove the reverse selector switch. Push on the "button" on the bottom. If the button is stuck or hard the move, it's time for another one. I had to replace one that was permently lodge in the up position, thus I was always in reverse! LOL.
GL!
dvsteg
06-18-2009 10:13 AM
civicSIfnatic
13
08-21-2008 09:48 PM
THEDirtyDseriesWOOT
10-17-2007 10:57 AM
thareddb
05-11-2007 11:34 PM
acuraLSSE95
02-28-2002 06:39 PM
Quick Reply: Hard wiring reverse lights in EG.
