gsr in 99 si throttle cable problem
i swaped a gsr into a 99 si, got a little problem, as of right now i have the throttle cable mounted to the strut bar, is there a special mount aplication out there to make it work?
Re: gsr in 99 si throttle cable problem (pulidos'si)
LMAO, WOW!
The Gsr is an under the manifold throttle body while and Si come with a b16 which is a in line throttle body, You have two options
either get a new manifold that puts the throttle body in the oe location
Or
Get a Gsr throttle cable
Or
1 Post
if you have a skunk 2 manifold or similar you can use the stock cable and put the 99si pulley on the gsr throttle body. or if you have the stock gsr manifold use the gsr cable.
92EG8
07-04-2009 10:22 AM
