Fuel and start problem?
Ok, I finally put my project car together, but having problems starting the car. Its a 95 EJ1 EX. I bought it as a shell, with eveything out of it.
When turning on the car, there is no click from the relay and fuel pump doesn't turn on. I checked the relay and only getting 1 wire with power. The wire is white with 2 silver dots, but no power going out of the relay which should be the Yellow and green wire. I then bypassed the relay and wired a power directly to the pump and the fuel pump turn on and started pumping. So I checked all the fuses and replaced some, and also changed the relay. Still no click, and no power to the pump. Checked for power on wires and nothing still. I would bypass the relay adn have fuel pump on but the EJ still won't start, just crank over.
Anybody know what's wrong? Anybody can help?
If you know someone that can fix the problem, let me know. I can tow it to the shop or place. Thanks
Re: Fuel and start problem? (killabs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killabs »</TD></TR><TR><TD CLASS="quote">what kind of harness u have on the car</TD></TR></TABLE>
I'm currently using a Si harness, but will be installing my EX harness that have for my tuck job.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killabs »</TD></TR><TR><TD CLASS="quote">yo whats ur number </TD></TR></TABLE>
pmed you
pmed you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killabs »</TD></TR><TR><TD CLASS="quote">what year harness is it</TD></TR></TABLE>
harness from a 93-95 Si
Re: Fuel and start problem? (Je$$eDB8)
Check your ACGS 15a fuse under your dash it is right next to your SRS fuse. If you cant find it look on your fuse diagram. LMK Jordan
Re: Fuel and start problem? (BlakeJ53)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlakeJ53 »</TD></TR><TR><TD CLASS="quote">Check your ACGS 15a fuse under your dash it is right next to your SRS fuse. If you cant find it look on your fuse diagram. LMK Jordan</TD></TR></TABLE>
I checked that one, and all the other fuses, but still nothing.
rymander
05-28-2011 03:12 PM
95turboeg
07-07-2006 11:38 AM
