hot engine, hot valve cover, hot manifold, will i be safe?
Old 09-02-2008, 07:09 AM
halocore's Avatar
Default hot engine, hot valve cover, hot manifold, will i be safe?
I recently swap over a 95 gsr into my 98 civic, and the engine gets really hot. I can probaly throw some hot dogs and eggs into and it'll cook. but anyways i've been keeping an eye on the temp gauge and it doesn't even make it half way.
My girlfriends dad said even if the temp gauge isn't telling you its' hot, it's a bad thing that it gets that hot and its' going to peel the paint off my hood. Then he started to tell me about his days of the muscle cars, and how some of his friends engine burn up because of how hot it was.
I remember my d16y8 never have gotten that hot before. so i'm just wondering if i'll be safe. I'm using the d16y8 raditor, so could that have been the cause too?
Old 09-02-2008, 07:19 AM
alphalanos's Avatar
Default Re: hot engine, hot valve cover, hot manifold, will i be safe? (halocore)
Make sure you have good airflow and your fans are working. Fresh coolant, check hoses. You might want to go to a bigger rad. but I think the d16 rad. is supposed to be able to handle it.
Old 09-02-2008, 07:54 AM
Syndacate's Avatar
Default Re: hot engine, hot valve cover, hot manifold, will i be safe? (alphalanos)
It's going to run slightly warmer with the D16 rad. All the Integra rads were full size.
Don't worry about it though.
This:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you have good airflow and your fans are working. Fresh coolant, check hoses. You might want to go to a bigger rad. but I think the d16 rad. is supposed to be able to handle it.</TD></TR></TABLE>
is boarder line bullshit.
Yes, you MIGHT want to do it, or you MIGHT not want to burn your money. There are plenty of civics driving around every day on GSR motors and civic rads, it'll just make you run a bit warmer, nothing to worry about at all.
As for your temperature gauge, [freak] your girlfriend's dad, that thing WILL tell you when it's getting hot to a level where you'll have to start worrying about it.
Old 09-02-2008, 09:36 AM
sageuvagony's Avatar
Default Re: hot engine, hot valve cover, hot manifold, will i be safe? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
As for your temperature gauge, [freak] your girlfriend's dad, that thing WILL tell you when it's getting hot to a level where you'll have to start worrying about it.</TD></TR></TABLE>
That's true, or else they would be completely useless.
Old 09-02-2008, 01:25 PM
halocore's Avatar
my oil should okay right? I shouldn't be burning any at that temp would i?
Old 09-02-2008, 01:37 PM
Mugen112's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by halocore &raquo;</TD></TR><TR><TD CLASS="quote">my oil should okay right? I shouldn't be burning any at that temp would i?</TD></TR></TABLE>
Your oil is fine. I used to have a '93 ej1 with swapped gsr in it with the half radiator. Then I went turbo...with no problems. You're fine.
Old 09-02-2008, 01:43 PM
eg_boi's Avatar
Default Re: hot engine, hot valve cover, hot manifold, will i be safe? (Mugen112)
get an automatic civic radiator if u want a bigger radiator for cheap, heard they were bigger but ive nver ran one. someone else might be able to confirm it.
but anyways like everyone else said u shud be fine
Old 09-02-2008, 01:46 PM
DTA-Zombie's Avatar
with a stock civic radiator you will run warmer - make sure your fan works - safe side get a dual core radiator w/ a good fan. Then fan will help w/ cooling and pull heat from the motor.
Old 09-02-2008, 01:59 PM
speedfreek128's Avatar
use the radiator for a Del Sol VTEC. the radiator is half size like other models but its thicker and the hose fittings are bigger so your larger B-series hoses will fit correctly. you can check junk yards but youd be better off getting a few one for not much more $.
FreshPurp
05-09-2013 11:51 AM
freefall365
10-24-2010 11:30 AM
AnthraxVX
04-09-2006 10:35 PM
acurastreetracer
03-07-2006 12:39 PM
Poopie
08-20-2004 06:45 AM
Quick Reply: hot engine, hot valve cover, hot manifold, will i be safe?
