speedometer is not working
i recently swap my motor and now the speedometer is not working. I switched out the speed sensor and still...i get nothing. It was working fine before the swap. do you guys know what it is?
Re: speedometer is not working (hondaman_csu_slo)
Did someone put an LSD in the trans you have? If so, did they forget to put the speedo drive gear on it? To test the sensor and wiring, remove the sensor from the trans and have someone spin the gear while you have the key in the run position. If the speedo shows speed, I'd check the gear in the trans. IF it still does not show speed, verify that the little coupler is still inside the sensor just in case it was taken apart and it fell out. You can also simply put another sensor on the wiring and do the same. Otherwise, go over all your wiring; there is a chance one may be cut if you used a different harness or if you cut some stuff out.
Re: speedometer is not working (RyanA)
thanks. that's a really brilliant idea. no i don't have lsd. i didn't touch the gears in the tranny at all. but i have one possible issue. I just looked at the engine harness. It is a 99-00 wiring harness. my car is a 96 honda civic (ek). I was looking at the green plug by the ecu and the part that comes from the engine is missing three wires comparing it to my harness that goes under the dash. I believe these two wiring harness are not compatible. am I correct?
I would also like the add that the tachometer is not working also. Is there a possibility that these two of the three missing wires can be the speedometer and the tachometer?
doubleoazn03
09-05-2008 10:33 PM
