Sway bar brands pretty much all the same?
I was gonna put a front and rear sway bar on my car. I have access to a wrecked 00 si, so im gonna take the 26mm front bar with the lca's and shift forks and ends links and throw it on my hatch. I also am going to start running a rear sway, but my question is are all sway bar's anc componies pretty much the same quality? I was gonna run the asr sub frame kit and a 22mm bar. Just wondering what company to go with if one is beter then the other or should i just stay with an oem ctr sway bar?
Re: Sway bar brands pretty much all the same? (Aushonda)
yes they're all pretty much the smae powdercoated mild steel
if you want to go with a slightly smaller bar but still have a nice improvement in handling over stock and not need the ASR I have a 19mm suspension techniques rear swaybar with all hardware for 125 OBO picked up and you don't even need aftermarket LCAs to utilize it since it mounts @ the shock bolts
Re: Sway bar brands pretty much all the same? (broketuner-Sol_Si)
thx for the replys guys, im gonna go ahead and stick with the 26mm front (got the whole front brake swap with lca's endlinks and sway bar for 100 bucks) and seeing how i got such a good deal on that i have enough money to get the asr subframe and 22mm ctr bar. i know password jdm and some other companies have the asr subframe brace and a brand new ctr 22mm bar with all the hardwear as a packege deal, anyone know who sells it the cheapest?
EJ1 wilcox
Suspension & Brakes
23
03-14-2006 12:49 PM
