fuel pump wont STOP priming
hey guys/gals, i recently swapped out my jdm d15b IM for a blox IM. My car has been idling at 2000+ rpms and when i turn my key 2 clicks the fuel pump primes, but doesnt stop, it just keeps going and going. My FPR is hooked up correctly as far as I know.
Any help will help. TIA.
Re: fuel pump wont STOP priming (BlakeJ53)
ill try that next, where can i pick one up? i dont have one just lyin around... and that's inside the cabin next to the door on the passenger side, right?
Re: fuel pump wont STOP priming (obuhmyuh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obuhmyuh »</TD></TR><TR><TD CLASS="quote">ill try that next, where can i pick one up? i dont have one just lyin around... and that's inside the cabin next to the door on the passenger side, right?</TD></TR></TABLE>
I would check out your main as well. You can pick one up from autozone, or take yours in to have it tested. You may have to search the forum on the location of the main, but its most likely going to be underneath on the drivers side somewhere just above the pedals (opposite of where your ecu is).
Re: fuel pump wont STOP priming (Mugen112)
thanks you two
i have a 1995 del sol, ill take a look-see when i get home from work, and ill check my ecu too, the guy that chipped it, didn't do the best job, but it never did this...
i would imagine it's fine to drive to work and back (20-25 miles round-trip), right? I've been driving it all day w/no serious problems...
crxzcracer
13
10-08-2004 06:31 AM
