master cylinder or brake booster?
Old 10-23-2008, 03:25 PM
mattbatson's Avatar
Default master cylinder or brake booster?
So, I have had this problem with the brakes for a while now, and am just now getting around to fixing it.
When coming to a stop, the pedal will continue to sink in. I've bled them (and I know how to bleed brakes) and they do not pump up, so I know it isnt air.
If I keep a steady pressure on it, it will continue to sink, even after stopped.
So, I pulled the master cylinder away from the booster and found it was rusty and wet from brake fluid.
Now, this would seem to indicate it is, in fact, the master cylinder.
So, if the booster has been exposed to brake fluid, does that mean it may also be damaged and I should replace it too? There is a rubber seal there going into the booster, but it seems okay....
whatcha think?
Old 10-23-2008, 03:45 PM
19slocivic97's Avatar
Default Re: master cylinder or brake booster? (mattbatson)
needs a master cylinder, fluid is leaking past the primary cup in the master cylinder causing the pedal to sink, booster should be fine
Old 10-23-2008, 06:42 PM
mattbatson's Avatar
Default Re: master cylinder or brake booster? (19slocivic97)
thanks, I'll keep my fingers crossed that the booster is okay..looks like bitch to pull...
regards,
matt
Old 10-23-2008, 07:30 PM
krysted9354's Avatar
very easy to take off, if this if for a 92-95 civic get a mc from a 91 civic ex its way better.
JJexpress
04-04-2009 07:22 PM
mattmw88
03-31-2008 06:08 PM
integra123
08-08-2006 05:52 PM
CRX7
11-03-2002 09:17 PM
KenTegra
04-07-2002 01:57 AM
Quick Reply: master cylinder or brake booster?
