main relay tripping!!!??????help asap
FUSE BOX ISSUE!!!??????help asap
97 ek four door= stock ex motor d16y8
here are some things i noticed..
-no cel
-relay clicking while driving on fuse box underdash...(is that main relay for the EK four doors?)
-at same time as relay clicking in back of fuse box...sounds like a vibrating phone...they go off at the same time...
-car bogs 1st gear at 1-2-3 thousand rpms then runs fine after...
-car has hard time starting sometimes (changed starter so wont be that)
i checked H-T for topics on "main relays" for my year
dont know if all EKs have same location for main relays
,,,things i found it seems like theres different locations
doooode so lost on if its a main relay or wat..livin in vegas know no one who could help
super rich when it runs...fumes just burns your nose when full throtld
i wont be able to check this for awhile so if possible someone give me a calll...thanks no internet at the house...
626 475 8121
Modified by Looneytunerz at 8:17 PM 10/24/2008
Modified by Looneytunerz at 8:38 PM 10/24/2008
Modified by Looneytunerz at 9:22 PM 10/24/2008
-no cel
626 475 8121
Not 100% sure if del sol's relay's are in the same spot as other Eg's and Ek's but the del sol relay is under the driver side fusebox.
Does you fuel pump always prime?
