drive axle wont go in
hi guys, im installing my friends clutch in his hatchy, i had no trouble taking the tranny, replacing the clutch, or taking the axles out. but the trouble started when i tried to put the axle back in. first it wouldnt go in the steering arm, so i took the whole thing out and it finnally gave up, then it wouldnt go in the tranny. so i took it out of the steerin arm to have less wait to make it easier for me but now it still wont go in the tranny. the teeth are fine but it just wont go in, if this ever happened to anybody please give me some tips. thanks
1 Post
Re: drive axle wont go in (JDAcrew)
Angle the axle so the snap ring is up when you go to pound it in. Or just line the axle up straight into the diff (have your buddy hold the knuckle back out of the way) and whack away Jim. Thread the nut so it's flush with the end of the axle so as not to mushroom out the end when you hit it.
Re: drive axle wont go in (hatchling37)
i get it to go half way into the diff but then it just doesnt move in completely i go at it with the hammer n it just doesnt move. i gues i just have to keep trying to line up the teeth and whack it some more
Are you the guy that installs new batteries on the TV advert by any chance "
IF IT FITS ... IT FITS .... WHACK WHACK WHACK ....
Re: drive axle wont go in (itsmejto)
nah i quit the battery business im a full time pockemon trainer now
i guess ill just have to whack it i didnt wanna mess anything in there tho but wattehells
If the old axles came out fine the new ones should go in just as easy. I've seen a couple cars that the splines inside the differential got twisted with the splines on the axle and locked the two together, but obviously this isn't the problem here.
I would have your friend line the axle up straight into the diff while you grab middle of the shaft and shove on it. It should only take you one good shove to pop it in there. If that doesn't work, line it up straight and hit it with a hammer. Just be careful not to smash the tri-pod joint.
Re: (The_Honda_Guy)
yeah the thing is the that we dont have a new axle its the old one, if it was a new one itll b easier but this one is just a pain. hopefully ill get it done tomorrow morning. also i cant seem to bleed the clutch it just doesnt get any pressure i wonder if a put the bearing wrong
Momentum
09-02-2010 10:06 AM
accord99power
05-12-2009 05:14 PM
jdmhonDAftw
05-29-2008 12:57 AM
tallblondkid
18
07-26-2004 08:10 AM
