How and DOES a voltage stabilizer help ??
ok i was wondering if them voltage stabilizers help ?? and if so what do they provide ? thanks
Re: (krysted9354)
Yeah they work, they give your motor a better ground and everything. If your motor grounds better it'll have a bit more power.. it's not like a lot of power but it'll help you out some.
Re: (iamthefollower)
HT White Ops
FV-QR
These things are a scam, just like fuel line ionizers and "Tornado" intake systems.
If you want to reground your engine, just buy some 2g wire scraps from a local stereo shop. It shouldn't cost you more than $10.
Re: (krysted9354)
honestly that's a different one from what I've seen before.. so i'm not sure how that one works.. the one that I used had a grounding post on it with the ground wires coming off to the motor..
Re: FV-QR (Eran)
c thats what i thought , but in this months import tuner or build up import magazine they used one of those on a 9 preldue and said it helped, so i didnt think that the magazine building there own car would bulshit ???
Re: FV-QR (krysted9354)
yeah cause the wires that came off the grounding post that I had were like 4g wires for it.. so I think that Eran is right on the wires, but if that's what they were using on there car then you could buy it and find out for yourself..
Re: FV-QR (iamthefollower)
Tell you what OP. Go dyno your car, put that hunk of **** on and dyno it again and see how much it helps. I bet it will be fractions of a HP
The only type of voltage stabalizer that helps you in any way and it would still be very miniscule would be something more along the lines of Buddy Club's stabalizer/grounding kit. Basically it only improves electrical response by a small integer and in my opinion as well as many others, it's a complete waste of money and time, especially that POS that was posted not worth it homey
