Where to get Eg Z6 motor mounts
ok so i just noticed tonight that 2 of my mounts are shottt. I just switched from my rex to this eg and its a little bit different, so i dont know how many mounts i have, its too dark for me to look and ive also been looking online for some and i cannot find them... can anyone offer up a little help plz.. thanks
GDD Member
Driver's mount by timing belt, rear tranny mount in same location as the CRX, top transmission mount in same place as CRX, front transmission mount in same place as CRX, and A/C mount which is in the driver's side fenderwell with two 14mm bolts that bolt sit vertically like hte front tranny mount has.
You can get the three most common ones at any parts store, but the a/c and front tranny mount are probably dealer only.
Re: Where to get Eg Z6 motor mounts (Electron Eg)
5 mounts in the eg. top tranny mount, lower tranny bracket, rear tranny bracket, top driver post mount, and ac bracket mount. I think you can run them all except the lower front mounts on tranny and engine and be ok but dont quote me on that. A great place to find OEM stuff is hondaautomotiveparts.com which has just about every part honda makes. mounts too. u can select vehicle year/type and which mount you need and pretty sure u can order online or over the phone. GL
Re: Where to get Eg Z6 motor mounts (Romo Pyro)
ok and one more thing? can i replace them one by one without a cherry picker or any support on the motor or trans???
97civicdx
02-09-2005 12:32 PM
p1driftfiend
06-03-2004 06:37 AM
