carbon/ un-burned oil all over rear bumper . .. .HELP
i have a question i have tons of carbon / un-burned oil shooting from tailpipe all over rear bumper. i have noticed in between the last 2 oil changes i have been 1 1/2 to 2 quarts of oil low, and its not leaking a drop anywhere !!!!
anybody know whats wrong? im thinking maybe the rings or seals are bad ? ? ? havent done compression test yet.
also i never had this problem before i converted from obd2 to obd1 about 3 months ago !!!!
i know its not running rich , it was just tuned and tuned good !!!
this is for sure oil on my bumper. . .
i just did a compression test and that all good, thinking maybe it could be valve seals ? ?
havent notice any smoke tho = (
well do a compression test and that will tell you if you getting oil past the rings, and if the compression test comes back good it may be your valve seals leaking oil down the stem of the valve.
If you're burning that much oil to have it all over your rear bumper, you should be seeing smoke... blue smoke. Most likely valve stem seals or piston rings are shot. Leakdown test will tell you where exactly.
piotrush
08-06-2005 10:15 AM
