Tilt Wheel?
Tilt Wheel?
Is swapping out a non-tilt steering wheel with a tilt steering wheel do-able on a EG? If so, is it very difficult? Any info would be great, thanks!
yes, it's easily done. just get a tilt steering column out of another eg. you need to unbolt i think it is 4 12mm nuts that hold the column up under the dash and 1 10mm bolt that holds the column in the steering rack itself in the engine bay. then of course disconnecting and reconnecting wiring. to change out the ignition you need a special bolt from Honda where the head snaps off after it is bolted down all the way. the down side of this is that getting your old ignition off requires a little bit of time and patience getting the old bolt out without the head on it. it's been a while since i've done this so it may not be 100% accurate but I know it's pretty close. hope this helps
SHG_Claudio
15
12-31-2008 12:37 PM
