ek cluster in eg ????
hey guys i want to put a 2000 si cluster in my 94 civic will it work and how hard is it going to be to install? i tryed to use the search but its not working right now and i need to know asap cuz i found one for a decent price and need to pick it up.
Re: ek cluster in eg ???? (mikegeezy)
it won't work in the eg dash.. you'd have to change the dash over and all.. havn't heard of anybody putting an ek dash in an eg, but have seen the DC dashes in eg's a lot here.. the only bad thing about putting the dc dash in it is you have to cut your door panels to shut the door.. its only noticable if the door is open but still..
I have seen ONE EK cluster done in an EG waaaay back when when I was first researching my mini-me swap, it looked good, but aside from the placement of the idiot lights, it just looked like dude put a bezel on an EG cluster, 9/10ths of people probably would not realize it right off hand, but keep searching, if your really interested in doing it id just wing it, itd be a good chance to learn some of the wiring back there.
i researched this last winter its not worth it...none of the stock cluster mount points fit, you have to ghetto rig it to fit there...there is alot of cutting that needs to be done to the shroud and in the end it always looks terrible. the problem is the 96-00 clusters are thickest from the sideview at the top and thinnest at the bottom, whereas 92-95 clusters are the exact opposite. if the gaps dont worry you id go for it...the plugs must be repinned but there are charts out there for that, i belive blueintegraboy has a huge thread on this and other cluster conversions...if your still interested in it when they fix the search function id check it out
SoCaLNaTIvE
10-25-2006 11:53 AM
djtrini
16
11-01-2004 06:05 AM
