HELP: ej6 window conversion
Old Nov 18, 2008 | 09:21 AM
LwdJdmR's Avatar
Icon2 HELP: ej6 window conversion
so i had everything ready, i just need the door harness.
i went to wire everything to its appropriate place
[the power window conversion is being done w/o the floor harness}
and well my driver window doesnt do anything the switch just makes
a small crying noise and goes away.
Also everytime i plug the switch to the harness the window regulator gets hot.
is that normal?
and finally will a 96-98 door harness be diff from a 99-00 door harness.
help!
Old Nov 18, 2008 | 05:07 PM
disordinate's Avatar
is that normal?
Definitely not normal for the switch to make that noise or the regulator to get hot when the switch is plugged in. Sounds like a broken switch or somethings wired wrong, this happen on both sides?
I don't see why anything would be different between those to harnesses.
Old Nov 19, 2008 | 10:55 PM
LwdJdmR's Avatar
well i had i diff harness but my pup chewed up the plastic on it so i had to get rid of that one. that harness before only had the wiring for windows and speakers.
and when i went to go try it out it everything worked perfect.
but now with this new harness which comes with wiring for windows, door locks, speakers, side mirors and tweeters. . . nothing works. :[ so now im wondering if i was the harness.
soninihon
Honda CR-V & Element
Jun 1, 2015 10:28 AM
djkurious
Mar 19, 2013 09:03 AM
LongJon
Jun 28, 2011 08:54 PM
sevenfc
Jul 30, 2008 12:54 PM
Ej1_coupe
May 29, 2006 06:39 PM
