93 sol::windows,cluster,rad fan,directionals not working >which relay or fuse?
93 Del Sol B20vtec
I visually inspected every fuse I the car. None of the fuses seem to be broken even though one of them might be. I was just curious... the headlights and radio work. The Dome light and brake light works. And the car runs well, I just have no input from any of the sensors since the cluster is lit up but not getting a signal from the speed sensor. Even the fuel and temp don't come up. This all happened while driving after hitting a bump uncharacteristically hard.
I checked for a bad ground or short but found nothing.
Which fuse or relay should I replace to get the power windows, directionals and cluster input back?
Thanks in advance, I needs this info to drive the car safely while I seal the rings on the new b20vtec setup.
m.glisson003
01-25-2013 08:22 AM
5thGenFanatic
11-06-2006 10:32 AM
