94 Hatch having trouble starting.
1994 Honda Civic CX w/ D16z6 VTEC
Completely stock.
My car is not starting during an overnight sit. When I turn the key I would not here anything, not a click nor motor turning. If I sit in the car and wait for a couple of minutes and give it another try, then it will start. I never had this problem before, it was starting fine until I took off my transmission and adjust my clutch. I put everything back but now I have this issue. I was wondering is it a bad ground, my battery giving out, or what else could it be?. Thanks.
Completely stock.
If you check your battery's voltage and it's 12-13v., then you should be ok. For some odd reason that you replace your clutch, and when you were putting some part(s) back, probably you missed connecting something back on. Maybe a ground to the tranny, the starter/solenoid wiring, battery terminals(tighten it). Or maybe your starter is bad, have it checked out.
MrRogers21
15
11-16-2012 06:44 PM
esean93
07-13-2008 12:02 PM
