ckf bypass trick
Old 11-14-2008, 07:05 PM
v8 integra's Avatar
Default ckf bypass trick
hi..i did everything http://technet.ff-squad.com/ckftrick.htm said to do to bypass the ckf after doing that i didnt get the p1337 code anymore but instead i got this.. P1382 Cylinder Position (CYP) Sensor No Signal.. any help would b greatly appreciated.. the car is a 96 civic ex with a gsr p72 obd2a for passing inspection only. thank you honda-tech!
Old 11-15-2008, 01:31 PM
v8 integra's Avatar
Default Re: ckf bypass trick (v8 integra)
bumppp
Old 11-15-2008, 09:13 PM
v8 integra's Avatar
bummmpp ttt please help!!
Old 11-16-2008, 08:59 AM
v8 integra's Avatar
i need help asap..car drives like shitt
Old 11-16-2008, 10:49 AM
96-EJ6 B18C's Avatar
Default Re: (v8 integra)
You didn't cut the CYP wires right??? You just tapped in to them??? I have done this on several cars and it works like a charm everytime.
Old 11-16-2008, 01:52 PM
v8 integra's Avatar
Default Re: (96-EJ6 B18C)
i use the red quick splices...bumpp
Old 11-16-2008, 02:12 PM
v8 integra's Avatar
bumpp
Old 11-16-2008, 04:22 PM
Hmmm.... Your positive you were using the correct diagram for your ECU configuration??? And have the correct wires tied together (blue/red to yellow and white/red to white)?
Old 11-16-2008, 08:12 PM
v8 integra's Avatar
ha im an idiot..i took a look at it today and the black wire got snipped off(black on civics and white on integras) all fixed..i appreciate u trying to help me out!!! all it was a quick splice gone bad...musta squeezed it too hard..
Old 11-16-2008, 08:26 PM
Nice, well that's an easy fix!
kissifur
06-19-2014 04:22 PM
dresslerb
11-11-2005 04:52 PM
Hard2Find
04-03-2002 07:40 PM
Quick Reply: ckf bypass trick
