oil pump gasket
oil pump gasket
does oil pump have a main gasket between block and oil pump. i called some people to see if oil pumps have gasket but they say that they dont need one or have one.
Re: oil pump gasket
Hondabond HT specifically is what they use for it. Also, you'll have to take the oil pan off to change the oil pump gasket along with quite a few other things, so make sure you have new seals and gaskets for those also.
Re: oil pump gasket
Honda bond works well for everything! I didn't have a oil pump pick up gasket(well at least I thought I didn't but found one later on) and used it for a gasket for the oil pick up.
