Blox Throttle boie problems
I just installed a Blox 68mm Throttle bodie on my 2000 Civic Si. Now after the install i've been getting power suges and Check engine and SRS. I pulled the code and P1129 came out. "Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than Expected Comprehensive."
What does this mean? And how would i go about fixing this? Only mods i have dont to the car are Intake and cat back exaust. plz help =/
Re: Blox Throttle boie problems
well clearly its the map sensor... Did you try resetting the ECU? Sounds like the ECU isnt use to reading the extra air coming into the intake...
if the ECU detectes low vaccuum aroudn 15 or so it could set off the map code even though the map is good.
glad OP got it fix't
idriveahonda
09-22-2011 02:06 PM
crfr230
04-20-2007 05:12 PM
thashadow
06-12-2002 11:35 AM
