gsr rear sway bar install on a 99 civic ex
Old 05-22-2009, 10:19 PM
Shaynepolevault's Avatar
Icon2 gsr rear sway bar install on a 99 civic ex
do the end links from a 2000 spec gsr fit a 1999 civic ex, i know the si ones do but do the gsr? want to get the gsr sway bar so let me know if the end links will fit thanks.
Old 05-22-2009, 10:42 PM
Default Re: gsr rear sway bar install on a 99 civic ex
im sure there is somebody that can help me. come on please thanks in advance
Old 05-22-2009, 11:16 PM
Fook_me_honda's Avatar
nope. you need SI/EM1 end links.
Old 05-22-2009, 11:51 PM
so i need the si endlinks and the d brackets? Do I need the brackets that go behind then. in the picture it would be part 30
http://www.hondapartscheap.com/south...ARM&vinsrch=no
Old 05-23-2009, 12:10 AM
nope just the endlinks. im pretty sure all honda d brackets are the same.
Old 05-23-2009, 09:18 AM
Icon2 Re: gsr rear sway bar install on a 99 civic ex
so please correct me if im wrong. I already have the gsr sway bar, so all that I need is si endlinks or blox adjustable endlinks, then all i need is two of part number 28 and 29, and also part 35 witch is the screws and bolts. But I do not need part #30? also can i use part number 29 witch is the bushing for the 13mm si sway bar for the gsr sway bar because it is only a 1mm difference, or do i need to get the gsr one? thanks in advance.
oh this is where i got the part numbers from.
http://www.hondapartscheap.com/south...t=0&quantity=0
Old 05-23-2009, 12:10 PM
help me out here thanks
Old 05-23-2009, 12:20 PM
bmoua's Avatar
All you'll need are the Si endlinks, the brackets/bushings/screws off the GSR sway bar fits. I have a GSR 14mm rear sway bar on my 99 Civic ex as well.
Its def. a upgrade for the 96-00 civic's that dont have a rear sway. I felt a good noticable difference on the streets and felt a huge difference during canyon running. I'm paired with stiff spring rates as well so the difference was almost night and day.
Old 05-23-2009, 12:24 PM
turnsignalandy's Avatar
you will need #30 to bolt it up, but i dont think it will matter if its from a gsr or em1. WILL NOT bolt on without #30
Old 05-23-2009, 11:36 PM
eksedan98's Avatar
Does anyone know if you need to upgrade the rear LCA on a 99 civic ex to fit say a 22mm rear sway bar. Or can u use the oem ones? Cause i keep hearing diffrent awnsers.
Old 05-24-2009, 11:10 AM
eksedan98's Avatar
Anyone?
Old 05-24-2009, 11:33 AM
ej1love's Avatar
on 5gen u do...6g? idk.
kensei
03-09-2009 05:17 AM
mr 636
05-21-2006 07:06 PM
EG6LS
Suspension & Brakes
12-29-2005 01:06 AM
jimmhatch
05-26-2004 08:33 AM
99civic_exSB
07-07-2003 05:17 PM
Quick Reply: gsr rear sway bar install on a 99 civic ex
