68mm blox racing throttle body question
i was going to buy this throttle body this Friday but i was curious would this throttle body work with my stock tps sensor?
Re: 68mm blox racing throttle body question
its a replacement so it should work, just take the one off your old one, put in on the blox and calibrate it and your good to go, make sure the intake manifold is port matched
Do you have to have a upgraded intake? I think so? you want the port hole on your manifold to match the throttle body hole right? i thought about buying the same throttle body......
as stated, its a direct replacement over your stock one, everything should plug right in if its legit. but you must have it port matched, or its pointless pretty much.
shahriar35
01-31-2010 12:13 AM
SPD DMN
04-12-2008 08:33 AM
Phatch99
06-10-2004 07:14 AM
