Replacing cam seal/plug
my 00 si is leaking oil.
Checked the dizzy, o ring is good
Replaced the vtec solenoid gasket
And still I have oil, so the only thing left is the cam seal/plug.
Now I have a few quetions.
First, which brand plug to buy, I see multiple when googlin, any recommendations? I know I'm not buying it from Honda.
Second, I found a decent write up on here about it, but it didn't have pictures. I'm certainly not a mechanic, but I'm pretty good with my hands and I like working on my car. But I do a lot better if I have pictures of to go along with the instructions. Any one have a better write up with pictures?
Third, the car has 145k on it and the timing belt was done around 105k. Should I replace the valve cover gasket, or just use some hondabond and call it a day. And does anyone have the torque numbers on the valve cover bolts?
Fourth, if you've read this far, thank you.
Re: Replacing cam seal/plug
I got S2 because the shop I go to had them in stock, wish I went with blox though. Its basically the same thing but like a third of the price. And personally I would replace the valve cover gasket just to be safe, and they are only like twenty bucks.
DC2NING
06-23-2004 02:38 PM
