Flywheel Weight
Old 03-16-2010, 10:11 AM
tacchan's Avatar
Default Flywheel Weight
What is the weight of the stock flywheel?
I found a flywheel on ebay: http://cgi.ebay.com/ebaymotors/LSD-R...#ht_3181wt_841
and a clutch: http://cgi.ebay.com/ebaymotors/ws/eB...ht_3656wt_1166
Do you think this will work ok?
Where can I find a cheap, quality flywheel? How much does Honda charge?
Old 03-16-2010, 11:01 AM
I'm not Rick!
rick_rabies's Avatar
Default Re: Flywheel Weight
if you pay someone to do this for you expect to sell your legs to pay for it.
its easy do it your self. search around for pics and DIY in the stickies.
buy this
http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
Old 03-16-2010, 11:05 AM
S2Integra's Avatar
I think civ/teg flywheels are around 18lbs. F1 makes 12 lbs and 9.75lbs flywheels.
Old 03-16-2010, 11:43 AM
tacchan's Avatar
I found an Exedy Clutch Kit with Flywheel http://cgi.ebay.ca/ws/eBayISAPI.dll?...#ht_2326wt_940
and a XTR Racing Clutch Kit http://cgi.ebay.ca/ws/eBayISAPI.dll?...ht_2573wt_1166
Which one is better? The XTR comes with a 8.5Lb flywheel and can handle 195HP and 181 TQ
Old 03-17-2010, 05:46 AM
Matt93eg's Avatar
I have an XTR Stage 2 clutch and 8.5LB flywheel in my LS and its been fine for 1 1/2 years or so now. I would say that exedy is probably the better brand of the two though.
IIRC my stock D16Z6 flywheel was like 18lbs.
Old 03-17-2010, 10:54 AM
tacchan's Avatar
When do you know when to replace the clutch and how long do clutches usually last if you use it for daily driving?
Old 03-17-2010, 11:34 AM
97twodoor's Avatar
Depends on how the driver is with a manual transmission. I've seen clutches outlast the vehicle as a daily driver, and i've seen them last 6 months as a daliy driver.
Old 03-17-2010, 11:36 AM
tacchan's Avatar
When do you know that a clutch needs replacement? When the engagement is high?
Old 03-17-2010, 11:39 AM
shifty35's Avatar
Usually clutches need replacing when they start slipping. Try to gently accelerate from a stop in top gear, 5th. If it stalls, clutch is probably ok. If it revs, clutch is on its way out.
Old 03-17-2010, 01:17 PM
97twodoor's Avatar
And there you have it.
Old 03-17-2010, 10:13 PM
tacchan's Avatar
Yup, I just started it in 5th gear and it stalled. So if it starts slipping, can I still drive the car to a garage to have a new clutch put in?
Old 03-17-2010, 11:01 PM
egsleepercivic's Avatar
I got an exedy clutch kit from these guys a couple of times and all has been good with good prices
http://stores.shop.ebay.ca/gripforce...&submit=Search
Old 03-17-2010, 11:11 PM
roycivic92's Avatar
exedy is best f1 is ebay trash
Old 03-18-2010, 06:40 PM
tacchan's Avatar
I tried looking for the Exedy clutch for my 2000 Civic HB, but i couldnt find it. Plus the XTR clutch comes with a 8.5 lb flywheel and can handle 195 HP and 181 TQ
Teamdiesel
01-17-2008 10:19 PM
Propulsion
04-14-2006 04:45 AM
m3dia_lab
09-28-2004 03:02 PM
propulsion1
07-08-2004 09:34 PM
lakerschamp2000
03-31-2004 07:48 PM
Quick Reply: Flywheel Weight
