front knuckles and axles
1. are manual axles the same as auto axles on an EG
2. and EK
3. can EG axles fit onto an EK?
4. does the front knuckle from a non abs EK fit onto an EG
5. what about a abs EK front knuckle fitting onto EG?
6. are the bearings the same between abs and non abs knuckles?
thanks thanks
2. and EK
thanks thanks
Seagull Management
Re: front knuckles and axles
Nope.
Auto and manual axles are the same. EG and EK axles are the same. The only difference is that if you have ABS you will need to use ABS axles, if you don't have abs axles then it really doesn't matter what you use.
homedefense78
08-31-2008 09:18 PM
