Engien runs fine until I hit Vtec then it cut's off!????!!
Hey guys like the title says, my car runs fine but when I hit Vtec at 5200 rpm the car cuts off in the same way as a fuel cut off?? Would se=ombody know what to do?
Re: Engien runs fine until I hit Vtec then it cut's off!????!!
CEL on? Have you tried pulling the codes from the ECU? And what do you mean cutting out? Like a rev limiter, or is breaking up and sputtering during VTEC?
Exactly like a rev limiter and also I have also checked the check engine code that comes on once in awhile recently and it's TDC sensor
It sounds like your car is in limp mode. The ECU does this to prevent damage to the engine. You need to diagnose and fix the CEL, then reset the ecu.
just pull the negative off the battery. which you'll pry have to do as is with whats wrong.
speed_demon018
38
02-11-2009 07:13 PM
Luserkid
18
03-08-2004 07:24 PM
