Repairing bent rim?
Repairing bent rim?
Hey guys,
Hit a massive crater (not pothole. crater.) the other day.. Didn't see it until i was right in front of it and there were two cars in the other lane so i couldn't swerve at all. Anyways.
Since it seems to only really be bent on the outside lip and it wasn't bad enough to blow the tire, I was just wondering if it's at all possible to fix a rim that's been bent like this without taking it somewhere.. And if not, about how much would it cost to have it repaired?
Thanks!
Thanks!
Re: Repairing bent rim?
If you hit hard enough to bend the rim I am sure your tires sidewall is comprimised in some way... I don't think it will be possible to fix something like that. You could heat it and knock it back out with a hammer but it will never be as balanced as is was before.
You can't fix that by yourself without proper tools. And you will never get it balanced correctly without a special machine. Your best bet is to go to a wheel repair shop and get it repaired the right way. Which would cost around $60-$120 where I live (CA). Don't really know how much PA wheel repair shops charge.
ha yeah, when i get back from school in a couple weeks i'll prolly just rock some steelies for a bit and then decide if it's even worth it to fix up/replace the "eh" 5zigen's or just save up for somethin a bit nicer.. maybe a set of slips..
