Integra Rear End Question
I already have this done (92 Si) but I need new calipers. I have a brand new set of 92 Teg LS calipers, but I'm not sure if those will fit on the 3rd gen teg rear. So do they? If not, could I use the trailing arms and stuff off the 92 LS to make them work?
Re: Integra Rear End Question
I could be wrong, but i'm pretty sure they're different. The DA will not work, you need DC trailing arms and calipers.
Did you have to use different brake lines or anything? Also, I found that the trailing arm bushings are the same and the rotors are the same but the trailing arms between the DA and DC are different...
asianflava
12-08-2008 11:14 AM
drew2
13
07-27-2006 07:50 AM
Natural Aspirations
07-14-2004 11:46 AM
