HELP ME! ORDERED HASPORT MOUNTS FOR MY H22 eg CIVIC
i lost my paper about how to install them. i need the measurements on passenger side, where to weld the new bracket!
any of you who know (h22 eg civic hasport mtr mnts owners), please help me out!
Re: HELP ME! ORDERED HASPORT MOUNTS FOR MY H22 eg CIVIC
Uhhhh, it isn't welded on the H23...... You just line up the grounding wire from the tranny to the framerail and then drill the hole straight through the frame and then slide your bolts in I'll be putting mine in this week in the second car so I can put up some pics if your still stuck
Straight from hasports website :
Performance mount kit for F or H-series engine swaps into the 92-95 Civic 93-97 Civic Del Sol and 94-01 Integra. After making some modifications to the engine bay, this mount kit makes swapping the F or H-series engine into the EG Civic and Civic Del Sol a bolt in procedure.
see that? Bolt in affair, no welding, they come powdercoated, no weldy weldy. just bolt and go and be happy you didn't settle for a B series
well, yeah, i meant the passenger framerail, lol, my bad on that, not the smartest..., haha.
well yeah, it came with an instruction booklet wen my stuff came in. well what ur doing, is it going to be the same as mine? since ur's a del sol, jw.
Here you go man i knew i had this link somewhere,
http://hasport.com/store/tech/egh2.pdf
del sol and EG are the same, and yeah, I trusted those 2 bolts, and so does hasport... if they think that it's good enough to make it that way then I don't question it. No offense, but how much do you know about building motor mounts?
any torque specs on the mounts!?!?!?!?!?
buck02
07-02-2006 10:33 AM
