94 Del Sol Vtec A/C Problems
Condensor turns on but still no cold air.... check the freon pressure and it was at 70psi... what else might be wrong?
Re: 94 Del Sol Vtec A/C Problems
Does the compressor clutch fail to engage?
Without the A/C running, the pressure on both the high and low sides should be 100 PSI or even a little higher, so you may be low on refrigerant (=leak).
turbotime
09-06-2005 12:41 PM
