manual to power windows swap help!!!
Ok I'm doing a manual to power window swap. My car is a 1995 civic Dx hatchback, I got 2 1995 civic ex donor doors. Now I know I need the floor harness so my power Windows an locks will work. My question is can I use the floor harness from a 1995 aura integra?
Oh look, I can change this
Re: manual to power windows swap help!!!
Actually, I'm pretty sure you can.... but you should check each wire pin by pin. But ... the 92-95 Civic and the 94-97 Integra share the same fuse box so it should be pretty easy and will work. You can also use the floor harness from a Civic 4dr with power options which are a little easier to find in j-yards. Hey if you're pulling **** from an Integra, you should also do this retrofit: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bdiy%5D-oem-92-95-honda-civic-lights-chime-retrofit-no-radioshack-crap-here-folks-2749779/
Actually, I'm pretty sure you can.... but you should check each wire pin by pin. But ... the 92-95 Civic and the 94-97 Integra share the same fuse box so it should be pretty easy and will work. You can also use the floor harness from a Civic 4dr with power options which are a little easier to find in j-yards. Hey if you're pulling **** from an Integra, you should also do this retrofit: https://honda-tech.com/forums/showthread.php?t=2749779
TylerB
11
07-30-2009 10:20 PM
alexg103
11-11-2008 04:49 PM
