93 Del Sol leaking roof
Two Piece
Like the title says,
I got a 93 Del Sol Si. Its known for the roofs to leak. Mine leaks on the driver side where the seal for the roof and the seal for the car meet. I know I could buy the new seal kit for it but I aint spending that kind of money for it lol
So my question is, is there a way to fix the problem with out buying the seal kit for it? Have any Del Sol owners with the same problem fix this?
Thanks
Kev
Thanks
Kev
Re: 93 Del Sol leaking roof
A lot of 93's leaked right from the factory, only fix I know of is to change them to the 95+ version.
Search around on here there's a couple threads with links to places that sell them cheaper then the dealer.
Two Piece
If it comes to it, I might have to go to the 95+ but thats only if there is really no possible way of fixing this. Im sure there is a way out there somewhere lol
Thanks for the help
Kev
I've heard of guys with Sols putting extra washers so when it clamps down it clamps tighter .
Do you ever take off your top?
For now until you have money to buy new seals, you can put silicone sealant in the top , you just can't remove the top from now on out until you find some seals.
Junkyard might have a SOL with ok seals
Two Piece
Yea I take the top off when I can. No A/C But its gonna start cooling off alot soon. So I wont be taking it off as much.
I know the silicone option is there but its not worth it if you like the top off.
And junkyards, yea Im gonna do that next. I doubt Ill find one. I live in DE lol Not too many yards around here. Still wouldnt hurt to look though.
Thanks for the advice,
Kev
Kev
Dood The best thing would be getting new seals. I know you said you don't to spend the cash but it's better to replace the seals than the seats, carpet, radio or anything else you have that is valuable that you want to keep dry.
Check http://www.hondaautomotiveparts.com/ thay sale factory parts but at cheaper prices.
Which pieces are you needing?
Are the seals torn at all or just getting tired?
if it is not torn you can condition the seals and that will likely solve the issue
conditioning the seals is pretty simple and should be done every 6 months or so
go to the auto parts store and get spray on silicone lubricant, and silicone lubricant gel (Shin Etsu Honda Grease) sold at Honda Dealerships
grab a few soft rags
take the top off the car
spray the rubber down with the spray silicone
get it nice and saturated
now gently wipe it off... you will get a lot of black nasty stuff on the rag
repeat this a few times until it looks a little better
once that is pretty clean spray a light coat on and let it sit for a few minutes untill it is mostly absorbed
next get the Shin Etsu Silicone grease and put a decent coating on the rubber... lay it on there somewhat thick there should be a mm or 2 covering the seals
wait about 30 min (the longer the better)
wipe off any extra silicone that is not absorbed
spray a light coat on again
put the top back on
the seals should be nice again as long as they werent shot to hell before hand
the top shouldnt chatter and squeak as much if at all now either
http://www.bernardiparts.com/Shin-Et...8798-9013.aspx
put the top back on
note that there ware 2 types of seal the first type had no built in rain channel so honda had came out with an updated seal kit later that had drain built into the seal theres a service bulltin on this where they tell the tech to glue the seal in place ... and sence where on water leaks rember to remove the rear window seal so the defog wont crack the glass which ther is also a service bulltin about
I think AGENT_47 has a good idea because the same thing happens to me.. I have a 93 del-sol si and it leaks alot on the driver side and only the driver side.. so yeah please help us ! LOL
as i stated befor honda came out with an up dated seal kit. the kit came out in 94 and that is why mat A G has had verry little prob .the service bulletin is 93-004 S/M SUPPLEMENT : DELSOL WATER LEAK REPAIR . PARTS NUMBER: ROOF SEAL KIT 72999-SR2-999 TIME NEEDED FOR REPAIR 4 HOURS
Agent 47 is sum what right .by putting grease on the seal will repel water but this a temporary fix and will need to be repeated offten. as water will once again find it way in.
Why waste your time, and do a crap temp fix when you could just a 95+ new seal kit a few washers to tighten it up, and keep your seals greased a little bit so they don't rot. You say you don't want to spend the money to fix it the right way the first time so your choosing to do a bunch of shoddy temp fixes that will with out a doubt leak again, and you'll be back at square 1 lol. If I'm not mistaken the kit is only $60.00
Yeah I had it saved on my old laptop I wiped the drive and can't remember the dealership website, it was around $66 ish for each side left and right seals
