244whp 5psi.. what do you think?
Old 08-24-2010, 08:09 PM
GORILLARILLA21's Avatar
Default 244whp 5psi.. what do you think?
I saw a car on craigslist that's completely stock besides 440 injectors with a t3/t4 turbo putting down 244whp on 5psi with a tune on a 95 eg hatch.. Is this possible or is he just saying that?
Old 08-24-2010, 08:22 PM
D16SiHatch's Avatar
Default Re: 244whp 5psi.. what do you think?
dunno what the engine is in question, and that is important, but even if it was an ls i'm thinking 5 psi on a relatively small turbo is NOT going to increase stock output by 100hp+
Old 08-24-2010, 08:24 PM
Scott53092's Avatar
^ Yea if he's got a b it's what I'd expect, but if it's a dthen you'd need a bigger turbo to hit 244 at 5 psi. Does he have proof he ran it on a dyno and showed that power?
Old 08-24-2010, 08:25 PM
SOrry I should have been more specific. It's a jdm b16.
Old 08-24-2010, 08:28 PM
D16SiHatch's Avatar
if its a b16 then 5 psi is not likely going to make that significant of an increase
Old 08-24-2010, 08:31 PM
What kind of whp would you expect from that?
Old 08-24-2010, 08:32 PM
Scott53092's Avatar
I'd say 5 psi might make it close to there...
Old 08-24-2010, 08:53 PM
phaphon's Avatar
my b16a sir11 with the p30 pistons sk2 tuner1s type r valve train sk2 manifold 750cc turbonetics turbo not sure on size with 8psi was 233 but with bent valves they said without the valves problem i should have been at 250 260whp
Old 08-24-2010, 11:30 PM
thumper64's Avatar
boost pressure is not an accurate way to compare power levels. Compression, cams, tune, the turbo, manifold will affect power. It's like saying a V6 will make a vehicle fast...even though in a Civic it will haul but a full size truck it's a dog. Not knowing the rest of the variables makes a huge difference.
Old 08-24-2010, 11:34 PM
H23_del_soul's Avatar
^ The truth
GSROWNSU
06-13-2008 02:01 PM
Dialectic
10-17-2005 04:30 PM
Becks Rex
09-23-2004 05:15 PM
yellowhonda88
08-11-2004 01:35 PM
7PSiEF9ZC
03-24-2004 03:22 PM
Quick Reply: 244whp 5psi.. what do you think?
