d16y7 idle fluctuating..
Hi Everyone,
My dad's car is having some problems..
It's a 98 Civic DX with an automatic d16y7
The idle fluctuates in park/neutral..
i would say 600 to 1500.. rpms
I have tried cleaning the IACV and that didn't work, so I replaced it with a new IACV.. Still same thing..
I've also checked for vacuum leaks, checked for any kind of misfire..
Could anyone here be of any assistance?
Thanks in advance.
Thanks in advance.
Re: d16y7 idle fluctuating..
Any CEL codes? If not, try bleeding the cooling system:
Bleeding may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below
Only in park @ idle? What happens when you/he drive it around? Did you try having the injection system cleaned either professionaly or tuneup in a can?
1) Double check for vacuum (EVAP, PCV, booster, FPR, cruise, etc.) or intake air leaks (TB and IM gaskets).
2) Test the resistance of the 2-wire ECT sensor under the distributor.
3) Test whether the TPS output voltage is correct at closed and wide open throttle and changes smoothly through the range.
4) Try adjusting the idle screw on the throttle body.
BlackJacket
12-08-2013 10:07 PM
DumpedSi
07-26-2012 05:26 PM
aggoodin
02-07-2009 06:24 AM
byronl
06-14-2006 08:26 PM
