Del sol gsr swap gets fuel no spark
As the title says my del sol is getting fuel and no spark at all i turn the key and its dead in the water just hear relays click ive checked my grounds numerous times when i did the wire tuck i did every wire one by one so i know that is not a issue I have replaced the dizzy and since then i am out of ideas any would be suggestions would be glady taken
Re: Del sol gsr swap gets fuel no spark
what im not understanding though is the del sol ran started perfect with the sohc and the gsr i got the motor from ran started perfect
does the dash light up? you must of missed a ground or don't have good connection to the battery if it's just clicking
Are you saying that the starter does not crank the engine when the key is in ON(III)?
Or does the starter crank the engine but it won't start?
if you did a wire tuck and the car wont crank, thats probably your issue, did you use the right ecu for the gsr? i would start by checking the resistance in each wire you tucked one at a time
You sure the battery isn't low?
Double check the transmission ground because it' s critical for grounding the starter motor.
Also check whether the rubber stopper at the top of the clutch pedal broke or fell out.
very good advise, the little gromet will stump the hell out of you the first time you run into the problem
jachrist
02-05-2010 10:46 AM
