94 Civic coupe - Electrical help with connector pin outs?
***This may be in the wrong section, sorry in advance. Also searched and looked through factory service manual, to no avail...***
Ok, so I'm tucking/swapping a 94 EJ1 Coupe. I'm confident in my knowledge of wiring and electrical (wire police cars daily), but I hit a snag and only realized after the fact. On the driver side of the firewall there are two plugs for the engine harness to connect to. Inside the car in the same vicinity of the firewall, the harness comes through the wall and immediately plugs into two large plugs (one brown, one light grey). So in a sense, if it is unplugged from both ends, you get a short (maybe a foot and a half long) engine sub-harness for the driver side of the car. I need to know the pinout for both ends, not necessarily function of each wire, but where the wires are pinned in on each plug.
EXAMPLE:
1/3/5/7/9/11/13
2/4/6/8/10/12/14
This is under dash end
12
3456
78910
11 12
13/14
These two are in the bay.
I hope I've explained it thouroughly enough for someone to help. If not I'll take pics to explain.
THANKS in advance!!
EXAMPLE:
1/3/5/7/9/11/13
2/4/6/8/10/12/14
12
3456
78910
11 12
13/14
THANKS in advance!!
Re: 94 Civic coupe - Electrical help with connector pin outs?
This is the harness as a whole.
This is the plug end that is under the dash.
You can see where it is obviously cut. I need to extend it but only noticed there are several wires the same color AFTER i cut it to extend. Then I realized I should have extended one wire at a time.
lolv8s
05-14-2013 09:47 AM
SiR Inspired ED7
11-18-2008 07:04 AM
