eg hatch vx/gsr swap will not idle
Old 03-08-2012, 11:51 PM
jjmose03's Avatar
Default eg hatch vx/gsr swap will not idle
So I just recently did a gsr swap on my eg hatch vx. Anyways my car runs great when i'm gong and just getting on it but the damn thing will not idle,I have changed the Iacv, check for vacuum leaks I just dont get it. I have a skunk 2 mani with gsr tb help would be much appreciated thank you.
Old 03-09-2012, 12:17 AM
lthao61's Avatar
Default Re: help please
If u search GSR swap into eg in the search bar you will come across an article and the correct ecu Pin out for wiring an IACV in your civic with a GSR
motor. if you already tried that then double check you coolant level and do the proper bleeding procedure to see if that helps
Old 03-09-2012, 04:34 AM
Former User's Avatar
Default Re: eg hatch vx/gsr swap will not idle
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Old 03-09-2012, 06:44 AM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
This is the first time I have seen anyone mention having to repin for the IACV. I am almost complete throwing a GSR into my VX and the only thing I have seen that needs rewiring is the 5 wire O2 sensor to a 4 wire and wiring up knock sensor.
Old 03-09-2012, 07:26 AM
jjmose03's Avatar
I have disabled the 02 in the ecu and knock sensor works. No cel, if I keep using the throttle it runs but as soon as I let of it dies.
Old 03-09-2012, 07:59 AM
I would think your vacuum hoses are the problem. I am worried about this myself because I put a skunk2 IM and didn't pay too much attention when I removed all of that. keep us posted.
ITSME4G63
14
06-29-2005 06:53 PM
CSprogR34
09-30-2004 11:09 AM
Sprayin DC4
04-05-2004 05:07 PM
Lookincrazy
04-18-2002 11:55 PM
Quick Reply: eg hatch vx/gsr swap will not idle
