97 Civic EX Exedy clutch issues
Sup guys. Just got done putting a fresh rebuilt head, 100k mile 5sp tranny, and new Exedy OEM replacement clutch in my civic. I have about 1k miles on it now. Ever since i first got it done, the clutch doesnt feel right. I know that the Exedy clutches are known to be a little softer than factory, but here are my symptoms. Instead of having a smooth transition when disengaging the clutch, it seems to be very touchy. Its like when you get to a certain point when letting off the clutch, it just fully releases. Also, when accelerating, the car "chuggs" a little bit. The best way i can describe it is it feels like if you were lightly pressing on the clutch and letting the clutch slip a little. It is not slipping, but that is what it feels like. I had my flywheel resurfaced and the guy said he had to take a little more out than he likes, but that it should be ok. Not sure if this would affect anything. And now i have a creek in my clutch pedal about 1/4 off the bottom. Sounds like the fork or release bearing not sliding smoothly on the input shaft. Hope im not too confusing. Anybody had these symptoms? Thanks in advance.
Re: 97 Civic EX Exedy clutch issues
Wanted to add that it also has a bad vibration when letting out on the clutch at low speeds and when your downshifting. Would having a flywheel that was machined down too much cause any issues?
