'98 Civic EX - New owner looking for guidance.
Hello all,
I'm new to the forums, a recent lurker finding great info, and even newer to the 6th gen scene. I have a 8th gen Civic, a FG2 Si to be exact, but recently, my GF got her car totaled in a flood and we just picked her up a 98 EX. So far, I love it, nothing like a 90's Honda, but being as old as it is and having almost 200k miles on it, it's starting to show its age. It gives me a reason to get under the hood which is nice, since i've been trying to learn more and more mechanically, being the DIYer I am.
It's had a tune up within the last two years but I know its gonna need a timing belt and water pump in the not too distant future. The other thing that has worried me is the transmission, its a 5-speed, but it grinds a little into first and second. Then when letting off the gas in first or second, it makes a very audible whirring noise until your back on the gas. I am going to change the transmission fluid soon, I don't know when it was changed last.
It also has an oil leak which the previous owner thought was the oil pan gasket, but I had a mechanic look at it and he said its coming from a bit higher up (on drivers side). I'm not sure what that could mean, but he said the oil pan needs to be replaced regardless since the drain hole is stripped. I have a new oil pan and gasket on the way, so i'll be doing that along with an oil change within the next few days.
It's got two CELs coming up too:
6 - Water temp sensor
23 - knock sensor
It also needs a power window regulator on the passenger side and a little other TLC on the inside. It was recently painted which is nice and has a front and back 2000 conversion.
I guess as far as questions:
What could the issue with the transmission be, other than being old?
What tranny fluid should I go with? I read AMSOIL or Redline was the way to go.
Where should I check for the oil leak if it isn't the gasket?
Should I be worried about those CELs that are coming up?
Any other advice, or things I should check on this thing?
Thanks guys
23 - knock sensor
Thanks guys
Re: '98 Civic EX - New owner looking for guidance.
I always use OEM Honda MTF or ATF. Probably the best idea if you planning on keeping it stock.
If the oil is leaking out the drivers side, it's probably your cam seals, or front crankshaft seal.
As for advise, if you're keeping it stock, always use OEM parts. They might be a little more expensive, but they will pay off in the long run.
I'm looking to do my Timing Belt, Water Pump, etc, soon. What things do I need other than the TB and WP. Tensioner? Also, what seals and gaskets do I need to do a complete job? I've searched around and found a new DIY, but all of them used different assortments of parts. I will get OEM of course, just looking for a sort of, definitive list. I wanna do this D-series justice.
Thanks
Thanks
Thanks
Thanks
Get this to hold the crank pulley
http://www.amazon.com/Powerbuilt-648.../dp/B0000TMLWQ
and two big breaker bars. Getting the crank bolt off is the hardest part.
Here's a kit that's all OEM and includes all belts and the water pump: http://www.ebay.com/itm/96-97-98-99-...ht_6418wt_1297
im surprised nobody mentioned GM synchromesh tranny fluid. i had a 3rd gear grind when i would put it in 3rd, regardless of how soft or hard, over 4000rpms. i did my research and was led to purchase 2 qts of gm synchromesh mtf. I really can't begin to describe how this has made my tranny work so much better. it has done wonders! i dont get the grind unless i punch it into 3rd.
its not OEM, I know. its not even MADE for honda. but you gotta trust me, it will work. just search synchromesh on this very site and youl see.
oh yeah, its like ~$20 a qt
Bad Brian
02-14-2010 11:58 AM
