Rear Top Hat
Rear Top Hat
hey guys got a quick question. i have a 97 ek hatch and i been hearing werid sounds all week comeing from the rear end. today i hit a pretty good hump in the road and heard something smack the plastic in the trunk. i pulled over and looked in the trunk and the rubber peice that sits inside the top hat shot out. only thing there was the strut and nut holding it on. question is why would that peice shot out like that?
Re: Rear Top Hat
ok thanks. ill start by looking at the shock. how would i know if the shock is bad? there isn't any fluid comeing out or anything. i did fell to say i just had new shocks put on by the way.
Re: Rear Top Hat
Easiest way I've found to test a shock or strut is the bump test. Push down on the corner of the car a few times, get it bouncing, and then let go. If it takes more than 3 up/down motions to come to rest, something's blown.
Re: Rear Top Hat
The assembly was put togther wrong.
Remove the shock from the car.
my guess is that the ring that is under the top mount is not there.
It slides onto the piston, and the mount sits on it. if you look at the shock, you will see the bump stop, then the ring(if it's there)
EDIT- Post a picture
Re: Rear Top Hat
There was no ring. The ring ur talking bout looks like a washer right the driver side has one and the one that popped out doesn't. I called the guy back at free tire and service and he said he forgot to put it back on lol. Damn near screwed my damn car up but he did say sorry lol. I'll never deal wit them again.
Re: Rear Top Hat
Simple fix. Make sure he doesn't charge you for his screw up.
_Cyclone_
03-23-2005 04:54 PM
GroundZer0
14
03-18-2004 12:12 PM
alfaaay
03-31-2003 06:21 PM
