Positive battery terminal keeps building corrosion
96 Civic EX
Positive battery terminal keeps building corrosion. I just cleaned it a few weeks back, I never had it build corrosion so fast again. I am wondering if condensation is build under the hood?
Has anyone tried anti corrosion sprays, do they work?
Re: Positive battery terminal keeps building corrosion
Strange never happened until late last year, battery looks ok the terminals clean up good, it is like a white powder corrosion, I might have to try anti corrosive spray.
i have a tray on all of the cars ive owned and never really had a problem, little to none corrosion. might want to give that a thought.
I use a spray myself, it sprays out a red gunk that covers the battery terminal. It says you can just spray it on, will clean out the corrosion that is there and then protect. I dont know, Mine doesnt corrode, my old mans builds a little ant hill every couple weeks though. We sprayed his, stopped it. I usually hit it with the spray during every oil change. Works great.
My battery is interstate--- no corrosion. (Bout 2 months old)
My old mans is a Napa gold (or whatever their best is) and its nothing but corrosion. His is a good 3+ years old though.
Check the cables, mine had corrosion on the terminal end and into the cable. i cut off the corroded part of the cable and put on a new brass terminal end and never had a problem since.
Sounds like your battery's being overcharged. But I don't know exactly what to do about an over charging condition. I just know when a battery over charges, it discharges acid.
I suggest doing a full battery and charging system test. Voltmeter to a battery with car off (12.5v - 12.8v), and when the car's on (14.7ish). Once car's on, rev to 3000rpm-4000rpm and check voltage.
(correct me if I am wrong about the voltages please, not too sure about the car on voltage. I don't have my car right now)
If all is fine, battery just may have faulty seals around terminals.
