97 Del Sol Si - need help with cable reel / clock spring
if my cable reel/clock spring was bad would the horn relay click?
i over turned my steering wheel by a tiny bit and was wondering if that could of messed up my cable reel/clock spring?
my wheel is off center just a lil. so when i had car jacked up and turned the wheel idk if that could of damaged it?
but my horn worked before and didnt work after. i hear a click tho so i dont know if that mean the clock spring is good or not?
lmk if you have any info
R.I.P. Mark
Re: cable reel / clock spring. need help
1 did youhave the steering wheel off the car
2 did you have the steering colum disconnected from the steering rack
if you answered no to both then you shouldnt have done anything to the clock spring
( check your fuses )
if you answered yes to either or both then ...well yes prob damaged ..get a new one
if you need to know how to set your new clock spring before you put it on PM me
More then likely you did damage it but I thought that could only be done if you removed the rack from the pinnon and didn't strap down the steering wheel
Resident Gearhead
able to slam the steering wheel lock to lock without breaking the reel.
Not sure about the clicking relay, but if you snap the cable reel the horn, CC and SRS might not
work. You'll know the SRS isn't working if the light stays on constant.
Well i have an interesting curve ball to throw into the mix. I have a SRS light displaying in my del sol and the clock spring is the first place i have been told to check for the problem. Seeing as this is an area im not very familiar with, how can i check this out?
where is the horn fuse? if you dont know ill give it a look tomorow.
No such thing as over turning the wheel. If the cable reel is centered correctly, you should be
but i want to check the fuse first and grounds tomorow. do you know where the fuse is for the horn?
also my car doesnt have CC its a 1995 civic dx sedan so i cant test that
Re: 97 Del Sol Si - need help with cable reel / clock spring
horn works now. it was just rusty. i hit it with a hammer and sprayed some wd40 in it and it worked. cleaned the connections too
MTracing
02-23-2012 03:46 PM
honda genome
01-19-2008 01:44 AM
HA0LEFIED
16
12-01-2006 09:26 AM
