Compression test results. Need help! 95 Civic EX
I did a compression check on all 4 cylinders and i was wondering if someone could tell me what the results mean. It has a very bad idle problem if that helps at all. boggy/low idle to be exact.
Cylinder #1: 200psi
Cylinder #2: 180psi
Cylinder #3: 160psi
Cylinder #4: 120psi
Also, there seems to be no fuel getting to cylinder #3.
Cylinder #1: 200psi
Cylinder #2: 180psi
Cylinder #3: 160psi
Cylinder #4: 120psi
Good, Bad…I'm the one with the gun
Location: Trapped in time, Surrounded by evil, Low on gas
1 Post
Re: Compression test results. Need help! 95 Civic EX
the leakdown will show where the leak occurs. the problem could be of many, valves, rings, intercylinder leak.
trecool44
06-19-2007 06:52 AM
