B&M Short Shifter Questions
Hey guys, so I'm in the process of installing my B&M short shifter.
I'm at the point where I have to install the shifter back to the shift linkage. The thing is, is I don't have the pin that goes in the whole where the linkage connects to.
What exactly do I need to order? Or does B&M not need some specific items. On the provided website, what parts could you tell me I need? Thanks.
I also have a pin from the front bushing that I'm replacing with energy bushings, am I able to use that pin? It seems to fit perfectly.
http://www.hondaautomotiveparts.com/...y5=SHIFT+LEVER
Seagull Management
Re: B&M Short Shifter Questions
You'll need the sleeve, the 4 O-rings that go with it (the sleeve has 4 grooves) You may or may not need the factory bushings, I really can't tell.
bonylad
09-15-2005 05:08 PM
