Tighten the timing belt
How do you tighten the timing belt on a d16z6.
Mine is loose and the belt is hittin the lower plastic cover so how would i go about and tighten it or should i get a new timing belt?
Re: Tighten the timing belt (94civicx)
loosen the the tensioner and turn the motor over by hand w/ a 19mm wrench (turn the motor clockwise)...it can only get so tight by doing it that way. then just tighten the tensioner back to 33ft-lbs (i think...check in manual first)
[Modified by hatchmobile, 7:12 AM 6/15/2002]
slide inside
10-22-2009 09:25 AM
