Help! D-series valve adjustment (Dist. Rotor?)
I said I don't want a title!
When adjusting the valves on a D15B7, upon starting you need to get the #1 cylinder at TDC (easy) and then the Distributor rotor pointing at the #1 plugwire. How the heck can you tell that? Am I missing something here, because I can't find anything on the dist. that points toward the #1 plug wire.
Help!
Help!
D Tranny Guru
Re: Help! D-series valve adjustment (Todd00)
pull the cap off..........look for the white tip on the rotor.......when motot at TDC it will be pointing at #1 or #4 wire terminal on the cap.
I thought that the D16 motors had the marks on the camgear that you line up with the deck of the block to tell you that the motor is at TDC?
Re: Help! D-series valve adjustment (Avante)
If I didn't and I adjusted #1 when it was pointing at #4, what would happen?
Re: Help! D-series valve adjustment (SuperDragII!!!)
you'd have adjusted the valves on the intake stroke when they should be on exhaust, causeing overlap, and possible damage.
sounds good then.
BTW proper procedure was to find TDC on the mark on the crank pully, then remove the cap, and make sure the rotor is pointing @ #1
Re: Help! D-series valve adjustment (DragII...Enfuego!!!)
I did that method, but the Helms manual and the Haynes manual were both very vague about the Distributor rotor being lined up. Neither one gave pics, hints, etc...they just said to do it.
Now I know. Thanks for the help guys.
bakin1988
05-14-2009 08:08 AM
SearchBeforeUPost!
09-24-2003 01:01 PM
crxaddikt
10-10-2002 04:38 AM
