How to pull studs out of gsr intake manifold?
Just put a new Skunk2 intake mani on a friends gsr motor and for the throttle body it was held in by two bolts and two studs in the intake mani...can you pull those out and use them on the skunk2 manifold? If so, how do you pull them out?
Re: How to pull studs out of gsr intake manifold? (delcamino)
put a nut on the stud halfway down, then put another one upside down, screw it against the first nut, when they lock together, you can use an open end wrench, and unscrew the stud from the mani.
